Hey guys and girls,
Got a small fuel leak from my petcock on a 1989 ZX10.
Really want to get this sorted as soon as possible.
Any ideas what would most likley be leaking?
Would it be the gasket?
Check if its the seal between the tank and tap thats leaking or the tap itsself, either replace the gasket between the two or pull the tap apart and replace the o rings and rubber face
Not 100% sure if its the tap itself or if its at the tank as ive not had the tank off yet.
Ive saw a wee drip coming from the bottom of the tap but could be running down.
Just wondering whats most common oart to leak on them.
its not really common for a tap to leak so it could be either of them
check to see if the seal kit come with all seals and if so just order the lot and change the lot :)
usually they are sold as a full kit so you may as well change them all
always best to keep your profile up to date then we know what bike it is :lol:
I would try and get one from the UK though personally!
even try your local kwak dealer you may be pleasantly surprised
Ill try phone a few dealerships tomorrow and see what the score is as there is no Kawasaki dealerships in glasgow that i can visit.
That was the only 1 on ebay i could find. None from uk sellers
