ybr125 Posted January 2, 2016 Posted January 2, 2016 Hi,Been a while since I last posted so hope everyones doing well..Im trying to get a bit of help with the lighting on my bike. Being a YBR its not got the best of lighting and from where you ride you've got naff all chance of seeing either the indicators or the warning light.I had a look around ebay and found a chap that does a low power but 85Db audio warning buzzer, which hopefully will remind me to turn the darn things off!Should be just 3 wires and I thought it would be a doodle ( Im usually quite good at these sort of things ) but I just cant seem to figure it out or the bikes wired oddly. Its stock and hasn't been tampered with apart from me adding 2 twin LEDS DRL.Buzzer has 3 wires, 2 red + 1 black. Should be a straight case of one red for each side of the live indicator and the black either to earth or you can connect it to the live side of the brake. The difference being that if its earthed it beeps with EVERY indicator 'flash' or if its connected into the live side of the brake light it will stay silent until the brake light is off then beep again if the indicator is still flashing. Should be simples...Try as I might I followed what I think should happen in the circuit with a circuit tester ( unfortunately I cant get to the back of the lights to test directly ) but just didn't get a pulsing circuit when the bulbs flash, very odd.Would someone kindly have a look at the wiring diagram for me and see which wire they think I require for the 2 flashers? I would like the 'beeper' to stay off whilst the rear brake bulb is lit and I think that's the YELLOW wire. Can someone kindly advise me for the other?Cheers,YBRhttp://2.bp.blogspot.com/-nWtJ8RuAk4k/U5JF5rwLYoI/AAAAAAAAFys/uRmSTNXZh44/s1600/post-6-1308683516.jpg Quote
iangaryprice Posted January 2, 2016 Posted January 2, 2016 I would do this in 2 stages. 1. Get it working the easiest way first, connect 1-red to Green (left indicator) 1-red to Brown (right indicator)Connect the black to an earth point. Once you have got it working like this then you can move onto stage 2.2. If it s working OK with the black earthed, then disconnect it and re-connect it to the yellow wire for the brake light. It will use the brake bulb to get its earth when the brake is off. When the brake is on the yellow wire will be +12v this will silence the alarm since its no longer earthed.When you say you have tested to look for the "flashing" signal form the indicators an didn't see the pulses. What tester were you using? Its best to use a low power test light with a bulb about 2w. LED testers and multi-meters can give misleading results.Where on the bike are you intending to put it. Under the seat might be a good place, should be able to get at the 3 wires you need. Quote
ybr125 Posted January 3, 2016 Author Posted January 3, 2016 Thanks for replying.I was using just a normal circuit tester for continuity.The lights at the front were quite packed so might have a look at the back ones as easier to access.Cheers. Quote
ybr125 Posted January 4, 2016 Author Posted January 4, 2016 Took the seat off instead of going through the headlight - a lot easier to follow what was going on..Anyway its fitted now under the seat ( with silence when brake on feature )Cheers for the assist. Quote
