seanycozzie16v Posted March 18, 2016 Share Posted March 18, 2016 yet another problem...bike has recently got very hard to start and whem giving it full throttle from idle it lets a big bang out of the carb and dies. what is this? lack of fuel or too much fuel? its a vl125 intruder btw Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted March 18, 2016 Share Posted March 18, 2016 Check your valve clearances first, if the inlet is not closing fully not only will it cause backfire but will quickly damage the engine.If clearance are OK, check the ignition timing, If timing is OK, check the carb, needle valve controlling the float level could be sticking/worn.While carb is stripped remove and clean all jets making sure they go back in the correct place. When you put it back on make sure there is a good seal between the carb/inlet and head. Quote Link to comment Share on other sites More sharing options...
