I have MOT due in next couple of weeks and the only issue I am having is that twist grip is moving a bit. So my idea is to take it off and spray some hairspray in and that should fix the problem, however I was unable to to take it off - I could not remove ignition and acceleration cables that are connected to the grip and throttle. I tried spraying part of the handle bar and then slide it back in. It did help but there is still some movement and I doubt MOT ppl will like.
So my question is - is there any videos showing how to remove twist grip and throttle ? All i need is to slide it off and slide it back in.
Normally i just stick the stanley knife through and stick some new ones on
