Foxy Stoat seeks Pig Posted July 31, 2016 Posted July 31, 2016 Need some help if possible. I eed to put a new bulb in the headlight on my Honda CG, hopefully before MOT. Problem is screw wont budge. Its all rusted and also the screw slot is mangled. How can I get it out and also would a need a special screw to replace it?Thanks.http://s800.photobucket.com/user/martash2009/media/IMG_20160731_205102130_1.jpg.html?sort=3&o=0http://s800.photobucket.com/user/martash2009/media/IMG_20160731_205102130_1.jpg.html?sort=3&o=0 Quote
Guest Posted July 31, 2016 Posted July 31, 2016 Soak it well with penetrating fluid first. Few days and a decent cross head Quote
Foxy Stoat seeks Pig Posted July 31, 2016 Author Posted July 31, 2016 Soak it well with penetrating fluid first. Few days and a decent cross head Thanks, probably should have mentioned I have given it a good soak a few times. The screw just starts to crumble now so it really is becoming a mess. Quote
Via Posted July 31, 2016 Posted July 31, 2016 Soak it well with penetrating fluid first. Few days and a decent cross head Thanks, probably should have mentioned I have given it a good soak a few times. The screw just starts to crumble now so it really is becoming a mess. Well if it completely crumbles away problem solved getting it out Can you get a set of grips on it? Looks a fair amount of head to get onto it. Failing that it's drilling out if you drill just the head off may be enough when lens off to get set of grips on that then. Finally there are these... http://www.diy.com/departments/ptx-mixed-damaged-screw-remover-set-54mm-5-pieces/702452_BQ.prd" onclick="window.open(this.href);return false;Personally whenever I've tried these they never work and end up drilling out but maybe worth a try for £6 Quote
Foxy Stoat seeks Pig Posted August 1, 2016 Author Posted August 1, 2016 Thanks all, will try the grips and see if i can pick up a pack of those screw removers. Not sure what screw i need to replace it with but i guess i wont know until i can get the old one out. Quote
