fishermanferg Posted September 23, 2016 Posted September 23, 2016 hi ive just,took delivery of my xv535 1992, its not bad for its age ,there are some age related rusty bits ,there a box like think under the bike it looks like I think some sort of collector box ,its in pretty poor shape will need replacing soon ,are these boxes a separate part of the exhaust system ,can the be taken of ,any info appreciated Quote
Tango Posted September 24, 2016 Posted September 24, 2016 Sounds like the exhaust collector box......they're well known for rotting on many bikes.....A replacement exhaust system may be needed...... Quote
eastanglianbiker Posted September 24, 2016 Posted September 24, 2016 yep common problem on them replace it or at t he very least drop it off give it a good wire brushing if it doesnt then fall apart give it a good coating of a heat proof paint it will give it a bit longer life then or if you can weld any places it does rot through just weld a plate over it Quote
fishermanferg Posted September 25, 2016 Author Posted September 25, 2016 thanks for the info ,can the collector box be separated from the exhaust pipes ,from underneath the bike ,don't know if they are different from a Honda cm I had the downpipes went into one end of the box and the exhaust pipes went into the other end ,which meant I had to take the exhaust pipes of is this the same for the xv535 Quote
eastanglianbiker Posted September 25, 2016 Posted September 25, 2016 no idea i know the rear downpipe seperates i think you would have to gt under there and have a look for any clamps to seewhere it splits Quote
