Phooey Posted December 2, 2016 Posted December 2, 2016 Ok guys. Some of you know that I have recently lowered my FZ1. Two questions: a) would this lowering affect my headlight alignment? and b) is there an easy way to check if it is out?I am asking simply because I am getting a few cars flashing me at night and I didn't on the old bike! Wondering if the headlight is a bit high? Quote
Stu Posted December 2, 2016 Posted December 2, 2016 Headlight aim can be affected by lowering the bike as dropping the back will make the front point higher Setting the aim is not always an easy thing to do you ideally need a light tester thingy that MOT man uses I would be tempted to just lower the light a bit until drivers stop flashing but so you can still see PS: Thanks for the donation Quote
Phooey Posted December 2, 2016 Author Posted December 2, 2016 Headlight aim can be affected by lowering the bike as dropping the back will make the front point higher Setting the aim is not always an easy thing to do you ideally need a light tester thingy that MOT man uses I would be tempted to just lower the light a bit until drivers stop flashing but so you can still see Poo! ... was hoping to know for sure. lol PS: Thanks for the donation It wasn't much but you are very welcome. A couple of quid every now and then isn't much but might help Quote
Chrissb6 Posted December 2, 2016 Posted December 2, 2016 Here you go.http://ridershandbook.com/how-to-align-your-motorcycle-headlight-for-mot.html Quote
Phooey Posted December 2, 2016 Author Posted December 2, 2016 Here you go.http://ridershandbook.com/how-to-align-your-motorcycle-headlight-for-mot.html Excellent cheers Chris. Quote
