I am about to replace rear brake pedal tomorrow the bike is a er6f 2015 do I have to bleed the system or is it a matter off a couple of bolts and 2 springs
Sent from my HTC One M9 using Tapatalk
You shouldn't need to bleed the rear brake if you're just replacing the pedal. The actuator rod from the rear master cylinder is normally connected to the pedal by a small rod and split pin. The rear brake light switch is normally operated by a spring that attaches to the pedal, and the pedal should be attached to the bike by a bolt through the pivot point and a spring that holds the pedal up. :wink:
