Desperate for help with my 125
Yeah they're pretty much new only 6 months old
Then you need to take it back to the place you bought it from and make them fix it or replace with a new bike.
Why is it that bad of an issue
Is there bike 6months old? If so it's under warranty and the dealer you bought it from has a responsibility to fix stuff that goes wrong!
I've changed the look of it so I'm just worried he's gonna say the warranty is void
To clean the carbs I've heard that you can spray carb cleaner directly into the air intake but I've heard it's bad to do that too. I'm not mechanically inclined enough to feel confident taking the Carb apart. Can I spray carb cleaner and would it work
No you have to take the carb apart and remove all jets and the float system. Then go crazy with the spray and put it back together when dry.
