DERBI SENDA 50 / APRILIA RX 50 / SX 50 EXHAUSTS
For geared bikes employing Derbi EBS050 / EBE050 / D50B0 / D50B1 engines.
Most aftermarket exhausts are designed with 2-piece header manifolds for the sake of quicker exhaust removal, and isolating vibration to prevent manifold cracking. That design isn't necessary. Not even Viton O-rings teamed with hi-temp copper silicone sealant withstand perishing.
Here's a few aftermarket exhausts with 1-piece header manifold design that doesn't leak fuel/oil all over engine cases, or damage the rider's eardrums.
Pedmoto SG-1
http://www.adrenalin-pedstop.co.uk/upload/images/b8c94-SG1.jpg
Metrakit SP3
http://rollerhaendler.scooter-attack.com/media/catalog/product/cache/41/small_image/600x/17f82f742ffe127f42dca9de82fb58b1/m/k/mk871d1631_01_1.jpg
Proma
The Proma's manufactured a few millimeters too long, so you'll have to make a bracket for the OEM muffler's hanger.
Or use one of these mufflers: Giannelli 34683HF. Arrow 52604SU
Which exhaust is most suitable?
Depends which characteristics you prefer.
Pedmoto: mid range - high rpm power.
Metrakit: high rpm power with gutless low - mid range torque.
Proma: low-mid range rpm torque monster.
High rpm - more explosive power?
Narrow power bands only give useful momentum with an 11T front sprocket and 19 - 24mm flat slide carbs. That's useless on public roads, and you'd have to skip 1st gear.
Tip
Use 6mm star washers on header manifold bolts.
