Suzuki Bandit 600 Mk2 rear shock adjustment tool
Yo
Just got my first bike and I know the rear shock can be adjusted to suit different rider weights, riding styles, and pillion carrying.
I believe there is a special tool required to do it, but I don't think I got one.
Can I use something else? Or where can I get one?
Cheers buddy.
I saw this universal one, but wasn't sure it would definitely work. I'm assuming from your reply that it would probably be OK.
https://www.amazon.co.uk/MOTORCYCLE-UNIVERSAL-SHOCK-SPANNER-WRENCH/dp/B001ASMHYS
Not sure to be honest, only used the factory one, which has a flat pad on it but don't know if that helps much. should be someone along who knows better than what I do!
Any C spanner with the correct dimensions should work. I have used mole grips before.
