EX GASMAN Posted July 24, 2019 Posted July 24, 2019 Hi I've had the Enfield a couple of months now and it's developed a rattle from.the exhaust. I've checked all the fixings and had a look down the pipe can't see anything. It is a 64 plate and has a Cat. Could that have come loose? Quote
Gerontious Posted July 24, 2019 Posted July 24, 2019 Most usually a rattle is from the heat shield and becomes apparent as things heat up at different rates and so expand at different rates. Only way to determine its exact source is to listen, it's unlikely to be the cat. Possible, but unlikely. Quote
