LearnerLEGAL Posted September 25, 2019 Posted September 25, 2019 What slip-on exhausts would you recommend for a Yamaha XSR 700? I don't have the cash for a full exhaust system refit but really want to open up the stock grumble a little. Nothing obnoxious but at the moment, the only person who can hear anything is the rider sitting on top of the engine. I shouldn't need an ECU flash with a slip-on, right or wrong?EDIT: Just seen on another post that it's not possible to use a slip-on with the xsr700 that you have to use a full system. Anyone know if that's right?EDIT EDIT: Ok, yep..have to replace the whole system. Quote
Gerontious Posted September 27, 2019 Posted September 27, 2019 That's normal for a bike that's not a huge seller, it's easier to make pipes fit than, usually, have to design an end can from the ground up that will only fit a specific model. By making the pipes, it means they can use an exhaust that's used on multiple bikes.One to consider is the Scorpion. £529 for a full system, I have it on my bike and it's great. Quote
