Hello dose anyone know,I’ve put a second hand carb on my bike and doesn’t start,do I need to change the injector,don’t know if there coded to Ecu.done all the normal checks,spark,fuel air.thanks
Not sure how it works,it’s a 2013 and has a electric component on the side off carb,been told it’s fuel injected carb.??i not sure.its the same bike as Aprilia 125 sx.got spark fuel going to carb,not getting to plug.thanks
Hi Glen not knowing the bike , but I think what you see there is a Throttle Position Sensor (TPS) Should have at least 3 Wires going to it, do you have a Workshop Manual or at least a Wiring Diagram for the bike?, Do you have a picture
Don’t and can’t find much about the bike.
,this is the carb.thanks
Thanks to all,got something to be getting on with,I’ll change the part for my old one and see.lest I know what it is know.thanks again
