M4v3r1ck27 Posted May 20, 2020 Posted May 20, 2020 Hi guysI have a Lexmoto Vixen 125 that seems to vibrate like a mother over 5000 rpm.She's fine at lower speeds and lower revs. The vibration is also accompanied by a very fast clicking which stops if I let back on the throttle.Plenty of oil, everything external is tight. Thanks Quote
Guest Richzx6r Posted May 20, 2020 Posted May 20, 2020 Hi guysI have a Lexmoto Vixen 125 that seems to vibrate like a mother over 5000 rpm.She's fine at lower speeds and lower revs. The vibration is also accompanied by a very fast clicking which stops if I let back on the throttle.Plenty of oil, everything external is tight. Thanks Are you sure you have a bike Quote
WD-40 Posted May 20, 2020 Posted May 20, 2020 Does it happen when the bike is stopped? Or does it only happen when moving? If it only happens when moving it could be a chain problem like seized links or knackered sprockets. You can feel that through the foot pegs too Quote
WD-40 Posted May 20, 2020 Posted May 20, 2020 Hi guysI have a Lexmoto Vixen 125 that seems to vibrate like a mother over 5000 rpm.She's fine at lower speeds and lower revs. The vibration is also accompanied by a very fast clicking which stops if I let back on the throttle.Plenty of oil, everything external is tight. Thanks Are you sure you have a bike That's always the first thing on the list to check Quote
Guest Richzx6r Posted May 20, 2020 Posted May 20, 2020 Hi guysI have a Lexmoto Vixen 125 that seems to vibrate like a mother over 5000 rpm.She's fine at lower speeds and lower revs. The vibration is also accompanied by a very fast clicking which stops if I let back on the throttle.Plenty of oil, everything external is tight. Thanks Are you sure you have a bike That's always the first thing on the list to check Also everything external being tight is good On a serious note how old is the bike? Quote
RantMachine Posted May 21, 2020 Posted May 21, 2020 Are you sure you have a bike That's always the first thing on the list to check Also everything external being tight is good On a serious note how old is the bike? Well, it's a Lexmoto so it can't be more than three years old or it wouldn't be on the road any longer Quote
