Mark wells Posted November 23, 2020 Posted November 23, 2020 Brought lexmoto arizona as project with 12 months m.o t replaced battery as it was dead and indicators did not work they now work but only when bike is not running is this a bad rectifier as I have ordered one is it a bad relay or stator problem the last bike I owned ran on coal electronics are new to me Quote
WD-40 Posted November 24, 2020 Posted November 24, 2020 Check the voltage across the battery when the bike is running. If the charging system is good it should be around 13V at idle rising to 15V at 5000RPM. Quote
