Simon13245 Posted June 18, 2021 Posted June 18, 2021 Hello guys. It's my first post on this forum and I'm looking for technical advice. Someone deleted my previous account, probably because I posted in the wrong place. Sorry, English is not my native language and I could find an appropriate place. Today bought Honda NSR 125. I bought it with transportation because I couldn't find one near me. First I noticed an oil leak, I opened the oil pump and it seems hoses are leaking. Did anyone of you guys had similar problems? Is it easy to fix? Planning on delivering this bike to the mechanic so he can check everything. Simon. Quote
Bianco2564 Posted June 18, 2021 Posted June 18, 2021 Hello and welcome. Good to another 2 stroke on here, I've got two. The leak does look like its coming from the hoses, most likely they are aged and hardened. The spring clips look correct, I have the same on my RGV. 1 Quote
Simon13245 Posted June 19, 2021 Author Posted June 19, 2021 13 hours ago, Bianco2564 said: Hello and welcome. Good to another 2 stroke on here, I've got two. The leak does look like its coming from the hoses, most likely they are aged and hardened. The spring clips look correct, I have the same on my RGV. Thank you very much. Two stroke actually sounds pretty cool, I love the design of this bike. Ok so the hoses need to be replaced. Thank you for your time Quote
