kraig1 Posted July 3, 2021 Posted July 3, 2021 Hi, I've got my mates thundercat in the garage and has had problems with leaking carbs due to cracks in the body. He bought a rough set of carbs to use as a donor. When I took them to bits I found that the bit in the pic is blocked. Is there anyway of getting them out to replace them. Quote
Bianco2564 Posted July 3, 2021 Posted July 3, 2021 Is it me or is that some rough soldering with a hole drilled in it? Where on the carb is that? Quote
Bianco2564 Posted July 4, 2021 Posted July 4, 2021 As its inline with the main jet its likely to be the air bleed to the main jet emulsion tube. Quote
