Joexxx Posted January 11, 2022 Posted January 11, 2022 hi all I’m new here, not long passed my bike test I brought a Yamaha ys 125 the breaks I’m sure are ubs they seem to be very weak they work but not as they should of anyone could help me I’d much appreciated thanks joe Quote
Gerontious Posted January 11, 2022 Posted January 11, 2022 (edited) Take the bike to a Yamaha dealership. if there is a problem with the UBS not applying enough force to the front or rear then they should be able to identify that and fix it for you. It could be many things aside from the UBS system. Worn pads on the single front disc. low fluid. a problem with the rear drum. see a dealership. or in your mind, the brakes just aren't as good as the bike you passed your test or took your CBT on. Edited January 11, 2022 by Gerontious Quote
