Schantelle Posted March 17, 2022 Share Posted March 17, 2022 Hi. I just want to ask for advice. I have a swift 150cc and it starts the doesn't start. It has compression. It has spark. Its got air. Not overfueling. New gaskets all around. When I start it it runs a bit then cuts off. The I try startin it again and it just swings. Then it runs battery down too fast. Please I just need help. Thanks Quote Link to comment Share on other sites More sharing options...
Discomfort Posted March 17, 2022 Share Posted March 17, 2022 Compression is good Spark is good - Is it a strong spark? Air - As long as its free flowing - Filter clogged? Fuel - You say its not overfuelling, but does it have enough fuel coming in? Is it carb or injection? Quote Link to comment Share on other sites More sharing options...
Schantelle Posted March 18, 2022 Author Share Posted March 18, 2022 Thanks for getting back to me. It's carborator. Airbox is off at the moment. The fuel bowl does get full. Strong spark. And compression is good. New velves and valve stem seals. I had someone redo all the wiring. And still nothing. Quote Link to comment Share on other sites More sharing options...
Stu Posted March 18, 2022 Share Posted March 18, 2022 Have you tired it with the air box and filter attached? Quote Link to comment Share on other sites More sharing options...
Discomfort Posted March 20, 2022 Share Posted March 20, 2022 Have you taken the jets out to see if they are clear? Fuels bowls can be full but its not good if its not being sucked up into the airstream Quote Link to comment Share on other sites More sharing options...
