david Posted January 24, 2023 Share Posted January 24, 2023 (edited) hello im new to the forum, can I ask for help please ? I have a non running bmwr1200gs , I bought the bike as a non runner its got a ews fault , so ive looked on line and most people with this fault replace the key antenna (uncoded) which I have tried bought a new one still same fault , so then I bought the motoscan app and a obdlink mx to read the codes there were loads a fault codes on it , the bike spins over but no start , anybody out there any idea , I did wonder if any body has an old working BMSK (ECU) to try to see if the motoscan app sees it then I would know its a wiring issue? ive tries tracing out the wires from the antenna to ecu and they buzzed out ok HELP PLEASE Edited January 24, 2023 by david Quote Link to comment Share on other sites More sharing options...
Stu Posted January 24, 2023 Share Posted January 24, 2023 Hi and welcome I think this is caused by a flat battery in the alarm system (dwa) Quote Link to comment Share on other sites More sharing options...
david Posted January 24, 2023 Author Share Posted January 24, 2023 thanks for reply , but I replaced the battery for a new one Quote Link to comment Share on other sites More sharing options...
david Posted January 24, 2023 Author Share Posted January 24, 2023 the 12v main battery is the one I replaced , I don't have a remote fob, thanks Quote Link to comment Share on other sites More sharing options...
Stu Posted January 24, 2023 Share Posted January 24, 2023 No the alarm system has a back up battery inside it these fail and can produce the same fault Quote Link to comment Share on other sites More sharing options...
david Posted January 25, 2023 Author Share Posted January 25, 2023 hello thanks for that my bike does not have an alarm fitted Quote Link to comment Share on other sites More sharing options...
exportmanuk Posted January 26, 2023 Share Posted January 26, 2023 Strange most do, its under the rear cover just behind the pillion seat its a long black box with a small round speaker in the top it takes 2 batteries I cant remember the battery type Quote Link to comment Share on other sites More sharing options...
david Posted January 31, 2023 Author Share Posted January 31, 2023 nope no alarm fitted , update ive tried a used ecu and chassis ecu , ignition switch and new antenna , still the same , only thing left is the wiring????? checked wires from antenna to ecu and all seems fine , there must be a problem in another part of the wiring? what's left??thinking of changing the loom , cheers Quote Link to comment Share on other sites More sharing options...
