Guest Posted August 12, 2008 Posted August 12, 2008 Hello,My GPX 250.....i was wondering if i could hieghten the suspension at the back to make it any higher? i looked thru the manual but it says only to remove and replace...thanks in advance for ya helpLuke Quote
Guest Posted August 12, 2008 Posted August 12, 2008 you could alter the length of the 'dogbones' that connect the shock to the linkage, can you take a piccy of the top and bottom mounts and i will let you know if its possible.Its quite a common modification on Bandits and older gsxrs, makes the biek turn in a little quicker. how much are you wanting to lift it by and why?? Quote
Guest Posted August 13, 2008 Posted August 13, 2008 enough so i dont rub lol i think the suspension maybe screwed how can i tell? i sit on it and i bounce on it to make sure if i go over a bump it wont rub and my mate tells me i have like 3-5 cm gap....that normal? Quote
Guest Posted August 13, 2008 Posted August 13, 2008 hmmm, it shouldnt rub ...how heavy are you??sounds like its fooked, you may want to consider getting a new shock.take some pics with you on the bik eand the bike alone, i'd be interested to see. Quote
Guest Posted August 14, 2008 Posted August 14, 2008 120 kg.....the bike manual says it can take like 360 lbs which is like 150kgand ok pics Quote
