niallt12 Posted September 5, 2023 Posted September 5, 2023 I was hoping someone on here could help me, I have a sinnis apache 125 that overheats straight away, bogs out if I rev it too quickly, the carb mixture screw and the idle doe not effect it and the choke seems to control the idle Quote
RideWithStyles Posted September 6, 2023 Posted September 6, 2023 (edited) Break this down. 19 hours ago, niallt12 said: I was hoping someone on here could help me, I have a sinnis apache 125 that overheats straight away, bogs out if I rev it too quickly, the carb mixture screw and the idle doe not effect it and the choke seems to control the idle Year? Definitely an Older one with carbs? I ll break it down. As tinkering with it may have created more problems. heating straight away- lack of fuel. Bogs out when reved too quickly - now this could be viewed as both ways misinterpreted without seeing it. 1) lack of fuel starves it 2) too much fuel is thrown in drowning it. So the choke works. Have you been putting in E10 fuel? have tou changed the exhaust from std? Edited September 6, 2023 by RideWithStyles Quote
niallt12 Posted September 6, 2023 Author Posted September 6, 2023 It's a 2008. I've been putting e10 in it and I have changed from the standard exhaust. Quote
RideWithStyles Posted September 6, 2023 Posted September 6, 2023 Only as a note but not saying its the sole problem without more info. Aftermarket exhausts especially with the baffle removed can make the bike run lean and have big "holes" in the power delivery. E10 burns / ignites differently and can slowly eat or make carb rubber seals swell. Quote
