2024 Ducati Panigale V4 SP2 30th Anniversario 916 First Look
The Panigale V4 SP2 30th Anniversario 916 pays homage to the Ducati 916 and is produced in a numbered and limited series of 500 units.
The Panigale V4 SP2 30th Anniversario 916 pays homage to the Ducati 916 and is produced in a numbered and limited series of 500 units. (Ducati/)
Every legend deserves to be celebrated, and Ducati is doing that in the only way it knows how—by introducing the 2024 Panigale V4 SP2 30th Anniversario 916, which pays homage to the iconic Ducati 916 drawn up by Massimo Tamburini. Like your bikes in limited trim? Lucky for you, this bike will be produced in a numbered, limited series of 500 units.
The rest of us will simply have to drool over the special livery and long list of carbon fiber sprinkled throughout. That livery is, of course, from the bike that Carl Fogerty won the 1999 Superbike World Championship aboard. Sweet, sweet history!
Not that anyone was complaining about the Panigale V4’s looks before, but it’s especially hard to argue with the styling on the 30th Anniversario 916 model.
Not that anyone was complaining about the Panigale V4’s looks before, but it’s especially hard to argue with the styling on the 30th Anniversario 916 model. (Ducati/)
In terms of hardware, the Anniversario 916 separates itself through the use of a billet aluminum fuel cap, front brake air ducts, an exhaust heat shield, plus carbon fiber mudguard and wings.
Five-spoked carbon fiber wheels are 3 pounds lighter than the forged Marchesinis on the V4 S and 7.5 pounds lighter than the Panigale V4 wheels, reducing inertial momentum by 26 percent at the front and 46 percent at the rear, for added agility.
Each Panigale V4 SP2 30th Anniversario 916 is numbered, with production number engraved on the steering plate. The bike will also come with a certificate of authenticity and a dedicated motorcycle cover.
Each Panigale V4 SP2 30th Anniversario 916 is numbered, with production number engraved on the steering plate. The bike will also come with a certificate of authenticity and a dedicated motorcycle cover. (Ducati/)
Braking package is equally as impressive, the Anniversario 916 coming standard with Brembo Stylema R calipers and the aforementioned cooling ducts, as well as a Brembo MCS master cylinder with remote adjuster. An STM EVO dry clutch offers classic Ducati sounds.
Below is a closer look at the Panigale V4 SP2 30th Anniversario 916 equipment list.
  • “30th Anniversario” commemorative livery
  • Headstock machined from billet with model name and bike number (XXX/500)
  • Brushed aluminum tank
  • Dedicated seat with “30th” logo
  • Carbon fiber wings
  • Carbon fiber front mudguard
  • Carbon fiber brake caliper scoops
  • Carbon fiber exhaust heat shield
  • Five-spoke split carbon fiber wheels
  • STM EVO-SBK dry clutch
  • Final drive with 520mm chain, specific sprocket, and pinion
  • Brembo Stylema R front brake calipers
  • Brembo MCS 19.21 (Multiple Click System) front brake master cylinder with remote adjuster
  • Front brake and clutch levers milled at the ends
  • Billet aluminum adjustable rider footpegs with carbon heel guards
  • Single-seat configuration
  • Ducati Data Analyzer+ (DDA+) kit with GPS module (included)
  • Carbon fiber open clutch cover (supplied)
  • License plate removal cover (supplied)
  • Billet aluminum mirror hole cover (supplied)
  • Billet aluminum fuel filler cap (included)
  • Certificate of authenticity and dedicated motorbike cover
The Panigale V4 SP2 30th Anniversario 916 will be available starting from March 2024, with an MSRP of $45,995.
2024 Ducati Panigale V4 SP2 30th Anniversario 916 Claimed Specs
MSRP: $45,995
Engine: Desmosedici Stradale 90-degree, liquid-cooled desmodromic V-4; 16 valves
Displacement: 1,103cc
Bore x Stroke: 81.0 x 53.5mm
Compression Ratio: 14.0:1
Claimed Horsepower: 210 hp @ 12,500 rpm
Claimed Torque: 90.6 lb.-ft. @ 11,000 rpm
Fuel System: Electronic fuel injection, 52MM elliptical throttle bodies
Clutch: STM EVO dry, multiplate slipper; hydraulic actuation
Engine Management/Ignition: Ride-by-wire
Frame: Aluminum
Front Suspension: 43mm Öhlins NPX 25/30 semi-active fork; fully adjustable; 4.9 in. travel
Rear Suspension: Öhlins TTX 36 semi-active shock; fully adjustable; 5.1 in. travel
Front Brake: 4-piston Brembo Stylema R calipers, dual 330mm semi-floating discs (w/ Cornering ABS Evo)
Rear Brake: 2-piston caliper, 245mm disc (w/ Cornering ABS Evo)
Wheels, Front/Rear: 5-spoke carbon fiber; 17 x 3.50 in. / 17 x 6.00 in.
Tires, Front/Rear: Pirelli Diablo Supercorsa SP; 120/70-17 / 200/60-17
Rake/Trail: 24.5º/3.9 in.
Wheelbase: 57.8 in.
Ground Clearance: N/A
Seat Height: 33.5 in.
Fuel Capacity: 4.5 gal.
Claimed Dry Weight: 381 lb.
Contact: ducati.com
The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 alongside the 916 and Foggy’s race bike.
The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 alongside the 916 and Foggy’s race bike. (Ducati/)2024 Ducati Panigale V4 SP2 30th Anniversario 916 STM EVO-SBK Dry Clutch.
2024 Ducati Panigale V4 SP2 30th Anniversario 916 STM EVO-SBK Dry Clutch. (Ducati/)The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 has a Brembo MCS master cylinder.
The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 has a Brembo MCS master cylinder. (Ducati/)The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 builds on the already impressive SP2.
The 2024 Ducati Panigale V4 SP2 30th Anniversario 916 builds on the already impressive SP2. (Ducati/)2024 Ducati Panigale V4 SP2 30th Anniversario 916’s embroidered seat.
2024 Ducati Panigale V4 SP2 30th Anniversario 916’s embroidered seat. (Ducati/)2024 Ducati Panigale V4 SP2 30th Anniversario 916’s billet gas cap.
2024 Ducati Panigale V4 SP2 30th Anniversario 916’s billet gas cap. (Ducati/)
Posted (edited)
How to ruin any potential buyers day, in Italy. Park absolutely any triumph next to it. Age and condition is unimportant. Then stand back and watch the fans arrive, crowd around the trumpet and completely ignore the Panigale!!
Edited by Gerontious
