Hmmmm, sure I’m understanding you?
The yoke (top part) and the triple clamp (lower part) need to be slackened by the bolts on the sides (normally a 8-10mm size hex), raised up first through the triple then up to the yoke. Ensure you have the correct height from the top of the yoke to the flush of the cap - that houses the preload adjuster (if it has one).
