Dave Glynn Posted July 31, 2024 Posted July 31, 2024 (edited) Fuel flows through overflow pipe and drains then stops, when engine switched off. could this be the fuel pump allowing fuel though and not sealing shut ? Edited July 31, 2024 by Dave Glynn Quote
Simon Davey Posted July 31, 2024 Posted July 31, 2024 (edited) @Dave Glynn It could be the carburettors, maybe the float valve (needle) sticking open, or a float filling with fuel and not floating. Edited August 1, 2024 by Simon Davey Quote
RideWithStyles Posted August 1, 2024 Posted August 1, 2024 Yep carbs, floats and seals is first check. Quote
