Admin Posted August 6, 2024 Posted August 6, 2024 2024 Honda Super Cub C125 ABS. (Honda/) Overview Honda’s Super Cub (or Honda 50 as it was originally called in the US) has been on our shores as long as Honda has itself. The 1962 CA100 was the bike in the “You Meet the Nicest People on a Honda” advertisements of the era. The Super Cub C125 ABS joined Honda’s lineup in its current form in 2019. As unique as its Trail125 counterpart, the Super Cub stands out as a hybrid between a motorcycle and a scooter. These days, it’s powered by an air-cooled 124cc four-stroke engine with programmed fuel injection. Like the Trail125, the transmission is a semi-automatic unit with a centrifugal clutch, which means the rider doesn’t have to deal with a clutch to row through the four-speed gearbox. Modern touches include LED lighting, Honda’s Smart Key (keyless ignition and storage locking), and LCD info screen. Large 17-inch wheels, tubeless tires, and a disc front brake are chassis highlights. ABS is standard. Pricing and Variants The 2024 Honda Super Cub C125 ABS is available in either Pearl Niltava Blue or Pearl Gray for $3,899. Competition <a href="https://www.cycleworld.com/honda/trail125/"><b>Honda Trail125, $4,099</b></a> <a href="https://www.cycleworld.com/story/buyers-guide/2020-yamaha-tw200/"><b>Yamaha TW200, $4,999</b></a> News and Reviews <a href="https://www.cycleworld.com/riding-worlds-friendliest-motorcycle-honda-super-cub/"><b>Honda Super Cub C125 ABS First Ride</b></a> <a href="https://www.youtube.com/watch?v=TEEMlIHn1bg"><b>How Much Power Does The 2019 Honda Super Cub C125 ABS Make?</b></a> 2024 Honda Super Cub C125 ABS Claimed Specs MSRP: $3,899 Engine: SOHC, air-cooled single; 2 valve/cyl. Displacement: 124cc Bore x Stroke: 50.0mm x 63.1mm Compression Ratio: 10.0:1 Fuel Delivery: PGM-FI w/ 24mm throttle body Transmission/Final Drive: 4-speed/chain Front Suspension: 26mm telescopic inverted fork; 3.5 in. travel Rear Suspension: Twin shocks; 3.3 in. travel Front brake: 2-piston hydraulic caliper w/ 220mm disc w/ ABS Rear brake: Mechanical leading trailing; 110mm drum Wheels, Front/Rear: Spoked; 17 in./17 in. Front tires: 70/90-17 Rear tires: 80/90-17 Rake/Trail: 26.0°/2.8 in. Ground Clearance: 5.4 in. Wheelbase: 48.9 in. Seat Height: 30.7 in. Fuel Capacity: 1.0 gal. Claimed Curb Weight: 238 lb. Contact: powersports.honda.com View the full article Quote
RideWithStyles Posted August 7, 2024 Posted August 7, 2024 I’m not a Honda fan but that is a Lovely looking thing that design still cues back to the original. Dont know why but id have thought they’d make it an electric version? its an urban bike, would be easier to put the battery pack in there, single gear, doesn’t need to go above 60 nor need to travel 200-300miles before fill up. Quote
