Fast indicators on offside; all indicator bulbs working.
Any idea what could cause this?
*edit* these are standard and not LED
Nearside are functioning fine.
Does anyone know if there is a separate relay for the ns to the os?
I tried listening/feeling for the relay but it's silent when they are on!
I don't know whether it's related but the brake light isn't working via either front or back.
Any help much appreciated!
Have you changed one of the bulbs . if so make sure you have fitted the right bulb for your model .
I haven't changed any but I only picked it up last week; it was already like this.
I will check the bulbs tomorrow as well as go on a hunt for the ground... would there be a ground specifically for the right side then?
Might have to break out the wiring diagram!!
My problem was the dealer put a 10watt bulb in what should be a 5watt.
Check the wattage of all your bulbs, if one of them different then change it to match the rest.
ROb
Thanks, any idea where the earth it?
A lot off the time earths for the indicators are under the seat onto the frame, just do all the earths, the int many. 8-)
  • 2 weeks later...
this happened to mine and as it ticked per flash the flash was off too. what i did was take them out and put them back in and it fixed it, seems it was the wiring or souldering maybe it were they have been knocked?
Thanks lewis; I dropped it off at an Auto-Electrician last week to fix the brake light and he's done that and the indicators.
He's a good chap and is going to replace my oil cooler hose while he has it so i've left it with him for a while. 8-)
