Christoph Posted September 16, 2008 Posted September 16, 2008 Hi all,I've noticed since a ride on sunday that my front brake lever now seems to judder when ever it is pulled normally. It happens both when stationary and moving. However, when i apply some upwards pressure on the lever and then pull it, it seems to move smooth and as happy as larry. It feels almost as though it's metal against rubber causing the judder. Front brake also seems a little spongy all of a sudden at the same time as the juddering started... brake fluid looks okay, disc seems okay... only thing i haven't checked since sunday is the pads.Any advice?Thanks. Quote
Guest Posted September 16, 2008 Posted September 16, 2008 if it feels like this even when you are not moving ?i would look at the lever itself ( pivot bolt may be loose ,corroding , need lubricating .... basically make it as free moving as possible ....especially where you say if you raise lever then do it it is smooth ..... Quote
Guest Posted September 16, 2008 Posted September 16, 2008 your lever pushes a cylinder into the mastercylinder, there are various seals inside, sounds like one of these have maybe moved out of place, check the dust seal hasnt worked its way in and is getting trapped too Quote
Christoph Posted September 17, 2008 Author Posted September 17, 2008 Fixed.Took the brake lever off and gave it and the bolt a bit of a clean, put it back on and it's now as smooth as a baby's bottom. Quote
