T180985 Posted March 13, 2009 Posted March 13, 2009 i bought a K&N air filter for my zxr400 but cant seem to fit it, the old standard filter comes out no problem but the K&N is more ridged so i cant get it into the air box. anyone know how im supposed to fit it? i dont really want to be cutting away at the plastic Quote
Stu Posted March 13, 2009 Posted March 13, 2009 pics i need my memory jogging and what the filter looks like i had a K&N in my zxr Quote
T180985 Posted March 14, 2009 Author Posted March 14, 2009 thanks... here are some pics taken from other sites airboxhttp://www.zxrworld.co.uk/zxr400/worksh ... er/af6.jpgairfilterhttp://tbn2.google.com/images?q=tbn:Rki ... A-4091.jpg Quote
Stu Posted March 14, 2009 Posted March 14, 2009 i cant see properly from them pics and its not enough to remind me what they are like i had mine 5 years ago Quote
T180985 Posted March 14, 2009 Author Posted March 14, 2009 ok will get some proper ones shortly thanks Quote
T180985 Posted March 17, 2009 Author Posted March 17, 2009 i dont know if this will help but this is a larger image of the air filter that i took http://gallery.me.com/t180985#100006/photoand ive tried finding a better image of the air box but cant seem to do any better than this guide...http://www.zxrworld.co.uk/zxr400/airfilter.html Quote
Guest Posted March 17, 2009 Posted March 17, 2009 i bought a K&N air filter for my zxr400 but cant seem to fit it, the old standard filter comes out no problem but the K&N is more ridged so i cant get it into the air box. anyone know how im supposed to fit it? i dont really want to be cutting away at the plastic i dont want to ask the obvious, but are you sure it is the right filter for your bike? how do they look for comparison? Quote
T180985 Posted March 17, 2009 Author Posted March 17, 2009 yea its the right filter, the standard one looks different but its basically the same shape the older model of my bike had a panel filter i believe Quote
Guest Posted March 17, 2009 Posted March 17, 2009 Looking at the exploded diagram below and the pictures of both filters, i think that the foam filter goes over the cage (plastic Ribs).However i suspect this is not the case with the K&Ntry it without the cage and see how you get on..http://i250.photobucket.com/albums/gg250/simonevans73/air-filter-1993-l3-zx400_bigKAE0330.gifReplacement FilterK&N Quote
Stu Posted March 17, 2009 Posted March 17, 2009 Looking at the exploded diagram below and the pictures of both filters, i think that the foam filter goes over the cage (plastic Ribs).However i suspect this is not the case with the K&Ntry it without the cage and see how you get on.. it had two cages one for inside and one outside the outside one holds the filter in place i think Quote
Guest Posted March 18, 2009 Posted March 18, 2009 i would suggest that the foam filter needs the support of the cages 11013whereas the K&N replaces all items in 11013A, s no cage, in or out and bolts required, this is down to the k&N having no pre-drilled holes unlike the foam filter, Can you try fitting the K&N without all the gubbins from the foam filter..? if it works, i'd suggest that it how it is too fit. but i'd keep all the bits in case you fit a foam filter again, or sell the bike on..was there no instructions with the K&N? Quote
Stu Posted March 18, 2009 Posted March 18, 2009 i think the inner cage creates the seal so all air is passed through the filter does any of the cages fit in or over the K&N ?im sure you use the outer and have to drill holse in the K&N edge for the bolts Quote
