Guest Posted November 20, 2009 Posted November 20, 2009 Quite an easy job, easier still if you know someone who has a bike lift Firstly get the bike supported, center stand or paddock stands etc.remove the caliper mounting boltshttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0033.jpgthen shuffle it off the brake dischttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0034.jpgAs you can see the advertised "just had all the brakes done" that was also listed on ebay when buying this bike...might also have been an exhaggeration of the truth, its filthy in there and the pads are shagged toohttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0035.jpgThe brake pad retaining pins are removed along with the anti rattle springs (take note of the way they are fitter for re-assembly), these are all honking as well. They will be spending some time with the wire wheel and some copper slip before going back to work(apologies for the poor focus)http://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0042.jpgthe brake lever is then pumped to force the pistons out, be carefull not to go crazy here as they can drop out. beso to put a thin bit of wood in the middle of the caliper to prevent this and any damage to the pistons.now is the time to start scrubbing the caliper with a toothbrush and brake cleaner, it takes a while but they do clean up.with the caliper pistons exposed, thin strips of very fine emery cloth can be pulled back and forth around the pistons removing any crap/corrosion, another blast with some brake cleaner and an application of copperslip will have them looking brand new againhttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0037.jpgits now just a case of pushing the pistons back in with the piece of wood and then pumping them back out again with the brake lever, re-applying copper slip each time the pistons are exposed until you are happy with the level of cleanliness and the even operation of the pistonshttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0041.jpgpins are cleaned up witht eh wire wheela nd treated to some copper sliphttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0050.jpgsome goes on the back of the new pads toohttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0045.jpgthe new pads are dropped into place (keeping one hand behind the caliper to preent them falling onto the floor)http://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0047.jpgthe cleaned up pins go back in along with the rattle platehttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0049.jpgthe caliper is then shuffled back into place http://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0034.jpgand tightened back up to the manufacturers spec (aledgedly)http://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0051.jpgthe fork lowers looked a bit ratty, so they were rubbed down and given a bit of painthttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0053.jpghttp://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0052.jpgmany thanks to Robin, who kept us both in tea all day and allwed me to use his ramp and facilities.http://i294.photobucket.com/albums/mm114/naughtyleelee/bike%20maint/AAAA0064.jpg Quote
Guest Posted November 20, 2009 Posted November 20, 2009 MAIN THING.... apply the brake lever several times to return the pads to position before heading out onto the road, I prefer to then push the bike and apply the brake, once the bike stops under the brakes i am then happy to take to the road with some careful braking..you could always leave one pad in place, instead of a piece or wood, and on some calipers, where there arent opposing pistons a large wrench or g-clamp will push the pistons back.and some pads can be changed without removing the caliper, always refer to YOUR manualyou dont need stands, just using the centre/main stand. a lift just brings the bike to a better level..i've even changed brakes with the bike on its sidestand.. Quote
Guest Mr Miller Posted November 20, 2009 Posted November 20, 2009 Hmmmmm?.....I'm sensing a trip up the Boro to see Lee & Robin!Good job, fella! Quote
cruz Posted November 20, 2009 Posted November 20, 2009 i've even changed brakes with the bike on its sidestand..Not got any choice, the draggie only has a sidestand. Quote
Colin the Bear Posted November 20, 2009 Posted November 20, 2009 I'd say you're being a bit too liberal with the copperslip. A smear is all that's needed. If it gets hot and drips onto the disc..........Don't forget the cable tie trick for easy bleeding. Quote
Guest Posted November 22, 2009 Posted November 22, 2009 your probably right there colin... thing is.. it was robins copper slip and well, ... i got a bit greedy.the bike is gonna be parked up over the winter now so i'll have another look at them before it goes back on the road Quote
Guest Posted November 22, 2009 Posted November 22, 2009 Thanks for taking the time to post up this tutorial ,have to agree about the amount of copper slip on there Quote
