Guest Posted September 16, 2007 Posted September 16, 2007 Hi Guys , i`ve got a problem with changing gear on my cbr , goes up all the gears fine , but coming back down it sticks in 4th /3rd and gear shifter does nothin , i then have to let my clutch out gently till clutch bites and this seems to free it off , (can hear a click/clunk sound on the bite of the clutch ) it then goes back down fine tried all the simple things , wd40 on linkage , adjust chain tension , adjust clutch cable , oil change , i assume its gonna be an internal problem , any one any advice as to how easy this job is ,what to look out for , or is it a job for my local friendly ,expensive garage any advice appreciated , thanks Quote
Guest philgale Posted September 16, 2007 Posted September 16, 2007 sorry mate i have no idea, i just call my bro whos a mechanic...but welcome to the site...jump in newbie and say hello Quote
Stu Posted September 16, 2007 Posted September 16, 2007 cbr what ? 400 600 ? f sport ? rr ?what is the exact model it could be a common problem could be clutch plates sticking ? Quote
Guest Posted September 16, 2007 Posted September 16, 2007 i had something silimar on one bike. have you tried lifting the lever back to the central position then shifting down again?the fault i had was the two springs that locate the gearlever went rusty so they collasped. if the lever doesnt return to the center it cant select the next gear as the mech doesnt reset as it were.so kick down, lift it back till you feel resistance & kick down again. if it works its that. dunno how to fix it on yours though. Quote
Guest Posted September 17, 2007 Posted September 17, 2007 thanks hooli , will give it a go later , not hopefull though as the clunk sound definately comes from inside gearbox , cheers anyhow , will let you know later Quote
Guest Posted September 17, 2007 Posted September 17, 2007 clunk could be it going into gear as the power comes on. it sounds selector rather than box at a guess. most box problems ive seen grate & grind rather than just refuse a gear.best of luck with it anyway. Quote
