Hi
Have just bought a new battery for my sons moped, comes dry with acid pack - I'm ok with filling, but the battery will need an initial charge.
My question: Is it OK to charge with a car battery charger? I have read somewhere that it will charge too high, is that so?
I have attached pic's of battery and charger if that helps.
Thanks in advance.
Nick
http://i956.photobucket.com/albums/ae43/minstermadness/battery/R0017680.jpg
http://i956.photobucket.com/albums/ae43/minstermadness/battery/R0017681.jpg
Posted (edited)
I believe you need a bike charger due to the charging rate... see if any of the internet sellers have any deals going on, Hein Gericke, M&P, theFastOne, Busters etc...
that charger charges at 20amps an hour, you have a 4 amp battery, simple math... bike chargers charge at a much lower rate, generally work on 20% of battery amps for the charge rate/hour...
Edited by Anonymous
you sure it needs charging? I normally add the acid and leave for ten minutes and it's fine.
Please feel free to correct me if I'm wrong though
I used my mates car charger on my bike battery and been fine since did that. It was a 6v/12v charger, but dont think was 20amps charger. Think was lesser, if my memory is right the bike ones are 6 amps i think? Am sure someone will correct me hehe
that also knackers the battery in you should always give new batterys full change
just put it on, bump start bike, run for a while to charge should be fine!
you should not use a standard car charger too many amps!
mine has a switch on though especially for bikes :lol:
i Bought a maximiser 360t.Different settings for car use and bike use.Wont charge at a rate above 0.6A to protect the bike battery and upto 3.6A for a car battery.
Analyzes and charges accordingly.Monitors hourly and tops up when required.
http://www.np-trading.co.uk/images/Paragraphs/Maximiser_360Ta.jpg
