Dale. Posted April 11, 2010 Posted April 11, 2010 Hi, my bikes in for MOT and the guy has mentioned my tyres that they are ok but close to legal limit just like the other topic... However i cannot for the life of me find the right tyre size or i don't understand them and if i have looked at the right tyres it's 70 pound for one tyre, not even a decent make i think (sawa is the make)Please help me understand Front tyre size 110/80 x 16Rear tyre size 130/90 x 15that are the sizes apparently but on Suzuki website, can't find the link it has p on the end or somethingahh found the link http://www.suzuki-gb.co.uk/bike/gz125k9/tech/mine is a k3 though. Quote
Guest Posted April 11, 2010 Posted April 11, 2010 another day.another dale problem to solve if those are the sizes of the tyre atm then get the same.. i'll pm you a link dale Quote
Dale. Posted April 11, 2010 Author Posted April 11, 2010 another day.another dale problem to solve if those are the sizes of the tyre atm then get the same.. i'll pm you a link dale It;s not a problem. I'm just confused. I'm unsure of the proper sizes will have to wait till i get the bike back to check which should be tomorrow or tuesday!!! Quote
Guest Posted April 11, 2010 Posted April 11, 2010 if thats the size on the suzuki website, then thats the proper size, also the rear is the same as listed on wemoto, front isn't listed... Quote
Guest Posted April 11, 2010 Posted April 11, 2010 Dale.Always go with manufacturers recomendations as far as sizes go.Your tyres :Front tyres: 110/90-16 59 P tube type Rear tyres: 130/90-15 M/C 66P, tube type As a rule of thumb, take the front for instance .. 110- (110mm section width [how wide tyre is ish])90 - 90% of the section width is the tyres height16 - mounted on a 16inch wheel59 - this is the load rating, how much the tyre is rated to actually take, weight wise.P- this is the speed rating, how fast the tyre is rated to. Higher the letter, faster it is rated, off the top of my head 'P' is up to 88mph Quote
Dale. Posted April 11, 2010 Author Posted April 11, 2010 Cheers WF, think i will order them from the same place though instead of mixing and matching as both need replaced.Thanks Dan very detailed what is the M/C for on the rear tyre then? Quote
Dale. Posted April 11, 2010 Author Posted April 11, 2010 funnily enough .. Motor Cycle ... iircAhhh, silly me. Found these think i'll get them on Payday.http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 780wt_1161 Quote
Guest Posted April 11, 2010 Posted April 11, 2010 Dale, have heard good things about the Michelin Pilot Sporty (they make many small sizes) my mate just had them fitted to his YBR You'll probably find they would be better than the OEM tyres!And im with (stupid) Dan on thay my front tyres cost more too Quote
JimiB Posted April 11, 2010 Posted April 11, 2010 i payed 40 quid for my rear tyre and that was fitted. grips not to bad either.although the tyre was a full inch bigger than the standard size .. does this matter much. i've done around 1000 miles since with no worries Quote
Lumor_uk Posted April 12, 2010 Posted April 12, 2010 i payed 40 quid for my rear tyre and that was fitted. grips not to bad either.although the tyre was a full inch bigger than the standard size .. does this matter much. i've done around 1000 miles since with no worries Width or height? Height would change your indicated speed. Quote
Takanta Posted April 12, 2010 Posted April 12, 2010 paid 85 for back tyre and 60 for front i think , and they were for my 125 , Pirelli sport demon tyres though , really good tyres Quote
