Lumor_uk Posted April 15, 2010 Posted April 15, 2010 The missus reckons it's a waste of money to buy 50 cones around £15 and practice my mod 1. I want to make sure my bike can get up to the 32km/h before wasting £75 on a test. It also struggles to get past 62mph (100km/h) due to its age, will this be a problem for the mod 2? Quote
Guest Posted April 16, 2010 Posted April 16, 2010 I just used reference points in the road for manoeuvres and manhole covers for swerve test lol. And it should be fine for test. Quote
Ingah Posted April 16, 2010 Posted April 16, 2010 AFAIK, unless they changed the rules (sorry, i took the old test) the 62mph is just a theoretical thing based on the manufacturer's figures ("capable" of 62mph) - you don't actually have to do 62mph in the test! The CG125 (i assume you're referring to the 1985 CG mentioned in your signature) is perfectly appropriate for the test. In fact i did mine on my old 2002 CG From what i remember, examiners are more concerned with you getting up to speed without hesitation, than whether you're top speed is 60 or 65mph.Practice can't be a bad thing, especially with the new harsher test and your old CG (and when practicing, remember that your speedo is likely to be under-reading your actual speed by about 10%). The swerve test is something you may need to put into practice one day to save you and your bike from potentially serious damage - easily worth £15 in cones to explain for the wife... Quote
Lumor_uk Posted April 16, 2010 Author Posted April 16, 2010 remember that your speedo is likely to be under-reading your actual speed by about 10%). The swerve test is something you may need to put into practice one day to save you and your bike from potentially serious damage - easily worth £15 in cones to explain for the wife... cheers but with regards to my speedo, as mentioned in the pitstop thread my speedo says I'm doing 80-90 when I'm doing 52 (GPS). It seems to register 30 okay. I have swapped clocks from a 1982 Cg125. Quote
NearOn Posted April 16, 2010 Posted April 16, 2010 I used the gaps between the white lines on an early sunday morning in a huge retail car park, seemed to help. And as another person said above, for the swerve, just drain covers in the road, obviously if safe to do so and no traffic around. And for the emergency stop, a long quiet road. Quote
Guest Posted April 16, 2010 Posted April 16, 2010 (edited) Its only £15 for the mod1 Not £75!EDIT, plus, if you know the dimensions, just measure how many parking spaces u need to go through for the corner in an abondoned or not in use car park Edited April 16, 2010 by Anonymous Quote
cypek Posted April 16, 2010 Posted April 16, 2010 Its only £15 for the mod1 Not £75!Unless he is prepared to do it 5 times I also do some practice in a car park between white lines Quote
Danny-B- Posted April 16, 2010 Posted April 16, 2010 Also .... the speeds you have to get up to on the MOD1 is 50Kph .... (32MPH) not 50mph so your maximum of 62mph is ok ... Quote
Aaron Posted April 16, 2010 Posted April 16, 2010 My instructor used tennis balls cut in half. If you make the distances harder then you need not worry about the fact that cones are bigger and therefore easier to hit. Good thing about the half tennis balls is that theres no problem if you run them over, unlike if you use half a brick or something. Quote
Lumor_uk Posted April 16, 2010 Author Posted April 16, 2010 Its only £15 for the mod1 Not £75!EDIT, plus, if you know the dimensions, just measure how many parking spaces u need to go through for the corner in an abondoned or not in use car park it's £15!!!!???? Are you having a bleeding laugh is that ALL!!??? must go check.edit: it wouldn't let me check, just told me booked...cost £15.50. Couldn't find how much it cost but anyway I've booked it for June 25th, though I think I'm on holiday then so will have to reschedule it. Won't bother with buying the cones How much is mod 2? Quote
