hi i just bought a non running sym fiddle 50 for my daughter.i got it going but the lights and electric start dont work yet the indicators and brake light works.is there a separate fuse [i cant see one]or what else could it be?
Hi, not particularly familiar with sym 50 but from what you say it'd be worth checking the engine start switch itself......... ie either check for continuity (when its operated) with a circuit tester or short the wiring on the switch out to see if the engine turns over when you do....
food for thought!
