I'm planning to start using my 125 to get to work sometimes (when it's fixed...), and i want to park it on the road right outside of the shop (it can be easily seen from the counter - the road is literally 4/5m away from the counter including pavement and there's almost always someone there). I figured i'm best putting a cheap alarm/immobiliser on it (not a certified system, just something to make a noise if it's moved). I want it all as convenient as possible, but i don't feel that an easily disabled alarm alone is enough actual security, so i want to combine this with some convenient physical security, to totally prevent joyriding, and make the professionals jog on to an easier target.
I was wondering if anyone has come across any alternatives to the traditional chain/cable through a wheel security (i want to avoid the dirty hands as i work with food) - something else i can instead use to prevent my wheel(s) being turned without permission (or at least ridden away!). And i can't use a disc lock because i have dual drums (and a bad memory i can't trust :wink: )
For example, something like Grip-Lock initially seemed good (as demonstrated here: .grip-lock.com/Grip-Locks/ ). However, not only is too expensive for what it is (£45!!), it's a little *too* easy to bypass, and the reviews aren't all great as it can jam on, and apparently be picked / hammered off, all too easily. So anything else? (for example, i spotted a motorcycle clamp, but it's far too bulky and expensive).
Maybe i'm looking for something that doesn't exist (hence why i'm asking, because i can't think of anything else) - i just want a low faff (and cheap - don't see the need to spend much money for something that's not even going to prevent the bike being lifted) solution, for situations like this, when i don't want to bring along my Almax chain and lock it up to the nearest lamppost a couple of streets away via the frame :roll:
(i want to avoid the dirty hands as i work with food) :
Big lock and chain is the best deterent.
Just wash your hands when you get to work. (As i'm sure you do anyway)
how about a big U-Lock, bungee it to the seat to carry it around, and slot it between the forks..to lock the front wheel.
and i have a grip lock, never had a problem, and still have my bike (s)
