inversteve Posted August 25, 2010 Posted August 25, 2010 Remove rear brake caliper from bike to get a pin removed so refited caliper with new pads and reattached brake pipe.Only problem cant draw any brake fluid through system.Hope someone can help.Thanks Quote
Guest Posted August 25, 2010 Posted August 25, 2010 you need to open and fix a drain tube to the bleed nipple.. normally 8mm spanner at highest point on caliper... Quote
2fast2soon Posted August 25, 2010 Posted August 25, 2010 brake fluid reservoir cap is off..? i.e. it should be. Quote
inversteve Posted August 25, 2010 Author Posted August 25, 2010 Brakes now bleed thanks for all your help Quote
Guest Posted August 26, 2010 Posted August 26, 2010 brake fluid reservoir cap is off..? i.e. it should be. Guess it wasnt then!!!!lol Quote
