gy 125 help ugently needed!!!need to get to work tomorrow
:( my bike has petrol oil everything an when i go to start it it has none of it it starts occasionly on a bump but dies shortly afer help please have no idea what it is also my frint was playing with the tick over screw and ino thats the obviousl solution but its back in the place it started so that shouldnt b the problem help please i have work tomorrow
I had a skim through my bike manual earlier today and came across some suggestions it gave when diagnosing problems. The first suggestion it gave was to make sure the ignition was on lol.
Honestly I havent got a clue tho, sorry.
But maybe make sure side stand is up.
Has it rained recently? if so it may have got in somewhere so maybe wait an hour and try again? (this has happened to my gf)
erm.... its prob something really embarracing, e.g is the kill switch off?
Last time you topped up with petrol, you did use unleaded right?
That is the extent of my awesome machanical knowledge :)
Hope it helps. if not then hope someone with a bit more knowledge turns up soon... :S
wind in the idle screw till you can get it to run, (may be fast......) then wind it out to the right RPM...
