hey all just wonderin if you can help me out here.
I have a company scooter were i work and before i got here it has been battered around abit, even got driven up a set of stairs.
and now the front wheel has what if it had one a tank slappin movement on the handle bars. I was just wonderin if anyone could tell any ideas for it and how to fix it? just i'm stumped
cheers,
Jay
Do you mean it's constantly trying to do a tank slapper?
If so check the front tyre is in good condition, no bulges and correct pressure etc
It could also be that the frame is bent/the tyres aren't aligned correctly, there is a guide on here on how to check this yourself but it's a lot easier to get a garage to do it with lasers.
i checked the tyre and the forks and all seem ok.
might take it to a garage then see what they say, porblem is its in france, i dont speak french hmm
jay, long time no see.. how are you mate..
get the front wheel of the ground and check for play in the bearings.. hold wheel at 3-9 and push pull, any movement = new bearings..
i'm good fella, hows your self?
right i give that ago tomorrow as well, if all else fails, google translate it is
yeah im good,
have you got a haynes manual for the GS... have a look in MOT checks and you'll see how to check the front end... same principle with your scoot...
i dont have the gs any more got a er6f instead. :D
i would just hand it back put part of my job is fleet maintance.... i am failin at the minute :oops: , its a job for sunday now, although it does prove for interestin riding until then
