indicators stay on and make a humming noise rather than flas
hi!
ive got a chinese maxus x dirt 125cc cheap jobbie. when i turn the indicators on they stay on and i get a high pitch humming noise rather than have them repeat as they should. any idea what it could be??
If you can pull the existing one out, a trip to a decent motor factors should see you right, or ebay or rs components or something similar lol
before you pull it out and disconnect it while indicators are turned on give it a gentle tap it might start working again it could just be the contact stuck inside it
If that doesn't work, give it a harder tap with a bigger hammer.......
Tapped it and knocked it till it rattled. Put another one on and its the same, both sides light up but stay on :(
Any other ideas?
Next step will take longer. You say you have replaced with a new relay and the symptom persists? This suggests a bad earth to me, this could be anywhere in the flasher loom (oooer :D ) Unfortunately it is a case of tracing all the indicator wires to see if they have chafed anywhere (againsts the frame eg) exposing copper to the a ground.
Probabaly a good idea to clean all the indicator connections whilst you are at it, disconnect, clean up (emery cloth) reconnect, check harness routing...
Have you got a multimeter? Would be able to confirm if you had a bad earth.... then just be a case of finding it ....
(1. hope that helps... 2. hope i'm not sending you on a goose chase lol)
not tryin to state the obvious but was it deffo the flasher relay you changed?.. only reason i ask is that i know when i went to do mine there were several relays in there..
is definanlty the right flasher relay :D
the bike hasnt even done 300 miles yet, i cant find any loose wires etc. im wondering if i should try fix the original relay incase it 'needs' to use that one, its a pretty spotless bike
