softwarez Posted November 2, 2010 Posted November 2, 2010 Hey guys, any clues on this?If I start at 0mph and go to 70 (lets say entering a motorway) if I give it hard rev's its all fine.. however, when I am doing about 30-40mph and have it drop down one gear ready for a fast pull away, the motorbike hesitates quite a bit until I put the gear up and lay off the rev's a little..I do have a slight gap where my End can is and I can see all the black deposits which has been leaking out over time, could this be the issue, or something else?Thanks. Quote
eastanglianbiker Posted November 2, 2010 Posted November 2, 2010 what bike is it what filters are on it how bad is exhaust blowing Quote
softwarez Posted November 2, 2010 Author Posted November 2, 2010 Apologies for missing out some essential info. I am in a lecture at the moment, mind was a bit numb .Suzuki GSX750FFilter - StockExhust blow - I'm actually not too sure! Its about 2cm across (the joint) and probably only the width of a hairline. Quote
eastanglianbiker Posted November 2, 2010 Posted November 2, 2010 could be something as simple as needing a good service and the carbs balancing.also is it an aftermarket end can if so it might mean the carbs need upjetting Quote
softwarez Posted November 5, 2010 Author Posted November 5, 2010 Yeah, it is an aftermarket can. How would I know if it needed re-jetting? and how easy would this be? and how would I know which size jets etc?Thanks. Quote
Rod York Posted January 8, 2011 Posted January 8, 2011 put the bike in for a service if you are unable to check & clean the carbs yourself.Areas to check if it was working ok & has started to play up 1.Air Filter 2.Fuel filter?3.Carbs- cleanlet us know how you get on Quote
