Ricco1 Posted January 3, 2011 Posted January 3, 2011 Hi allI own a Honda 160GL Megapro here in Indonesia. It's a 2005 bike, similar to a CG I guess.I noticed a slight petrol leak from the tank the other day. I took it in to a garage, they said they could get it repaired for me, by welding. When they took the tank off though they noticed that it had been repaired previously, with some kind of glue. They say this prevents it from being welded. They applied more 'glue' for me, said it should be OK for a while.There is still a slight leak.I'll only have the bike for another 3 months so I don't really want to go to the cost of a new tank, painting, decals etc. I'd like to do my own repair if possible.I've tried to remove the tank but I'm having some difficulty. I removed the seat and side panels, and the 2 bolts at the very back of the petrol tank. I also removed the fuel line from the tank. Now I'm stuck, as I can't work out how to remove the tank! I've tried pushing it backwards and forwards, it does move a little, but I can't lift it off.You'll more than likely not know the exact model but I'm hoping that most small honda's tanks might be attached in a similar way. Any ideas anyone?Also, do you think a 2 part exopy, similar to Araldite, might be suitable to fashion a temporary repair?Thanks for your time.Rich Quote
eastanglianbiker Posted January 4, 2011 Posted January 4, 2011 to remove the tank after removing seat fuel line the bolt at rear u should just have to lift rear of tank slightly and pull towards the back of the bike it will then lift off as it should only be pushed into 2 rubber buffers at the front Quote
Ricco1 Posted January 4, 2011 Author Posted January 4, 2011 Thanks for that. Eventually managed to remove it, located the leak, exopied it, seems a good repair so far! Quote
