argentum40 Posted May 17, 2011 Posted May 17, 2011 ... can any of you ID this master cylinder assembly?Now its on my good RS and assumed it was the correct one for the bike however the RS125DX brake light switch doesnt fit and the brake lever is different..Hope one of you lads knows as getting tired of ordering bits only to find the part i am replacing is none standard... http://i77.photobucket.com/albums/j56/argentum40/17052011219.jpghttp://i77.photobucket.com/albums/j56/argentum40/17052011220.jpghttp://i77.photobucket.com/albums/j56/argentum40/17052011221.jpghttp://i77.photobucket.com/albums/j56/argentum40/17052011223.jpg Quote
Stu Posted May 17, 2011 Posted May 17, 2011 could always try and get a banjo bolt for the brake line with the switch built in if you get really stuck http://www.moto-racing.co.uk/ccp51/media/images/product_detail/HEL%20Single%20Banjo%20Switch.jpg Quote
argentum40 Posted May 17, 2011 Author Posted May 17, 2011 could do Stu but need a brake lever too as the other one is kinda short been snapped off at some point Quote
eastanglianbiker Posted May 17, 2011 Posted May 17, 2011 would be easier to buy a complete master cylinder off ebay than try and work out what that is off Quote
argentum40 Posted May 17, 2011 Author Posted May 17, 2011 EAB i thought of that but then would end up with non matching levers and even then master cylinder assemblys are not cheap.... i would also have the problem of tryin to get one which would take my brake line etc... Quote
argentum40 Posted May 17, 2011 Author Posted May 17, 2011 This one looks like it...http://cgi.ebay.co.uk/Suzuki-GSX550-Fro ... 45f482ad4anow the question is does anyone know wher ei can get the proper brake light switch as the one listed in searches is the wrong one.. Quote
eastanglianbiker Posted May 18, 2011 Posted May 18, 2011 with the age of your bike was it ever fited with front brake light switch,if it wasnt then i would agree with stu and go for the banjo bolt with switch built in Quote
argentum40 Posted May 18, 2011 Author Posted May 18, 2011 yeah EAB it was fitted with a brake light switch on both the front and rear... i am looking at one of those banjo bolts with integrated light when i figure out which one i need size wise Quote
argentum40 Posted May 26, 2011 Author Posted May 26, 2011 Found out this master cylinder is off a Honda 250n Superdream... got the brake light switch for it and its good to go Quote
