Comrade Posted September 11, 2011 Posted September 11, 2011 Another one of my diagrams, only thing in not sure is the timing of Signal...however i feel this is safe Quote
littlecat Posted September 11, 2011 Posted September 11, 2011 for me, its signal as soon as you kick the bike into gear.thn do all checks before pulling out Quote
Comrade Posted September 11, 2011 Author Posted September 11, 2011 i was told from instructor that if i signal before im ready it may cause driver to brake for no reason, thus causing adverse situation... Quote
littlecat Posted September 11, 2011 Posted September 11, 2011 but once your in gear you are ready? Quote
Guest Posted September 11, 2011 Posted September 11, 2011 Mirror, signal, lifesaver, manouvre.... thats what I was taught? Quote
techno Posted September 11, 2011 Posted September 11, 2011 Well as am not doing a test I dont indicate if theres nothing there that is going to impede me moving off then theres nothing to inform about the possibility am going to move off. Quote
Comrade Posted September 11, 2011 Author Posted September 11, 2011 personally i figured my instructor over complicated most things and wanted to talk about his new car most of time, hence why i decided to go alone lol Quote
iiisecondcreep Posted September 12, 2011 Posted September 12, 2011 Not sure I agree with this.Oh, wait.... the instructions are in reverse?? :/Don't understand 'full reach around check, grabbing handrail'?Re 'inching out'. Avoid if possible, if behind something big then maybe not possible but if behind a car you should be stopped far enough back that you don't need to inch out. If you do need to 'inch out', you shouldn't be signalling yet. I agree with not signalling until you are ready, I was also taught not to signal until you know its clear as causing another approaching vehicle to slow down you can be marked down.I was taught same as Vicki, mirror-signal-lifesaver-manoevre. Quote
Rollingskies Posted September 12, 2011 Posted September 12, 2011 I got two minors for not pulling away quick enough after doing the works on my stop and starts. So remember after that lifesaver, no fiddling around - go! Quote
Throttled Posted September 12, 2011 Posted September 12, 2011 As said, mirror signal manouver, all of why should be done once you are ready to move off. Quote
