Hi everyone
got a little problem with my sportcity 125 carb. was changing fuel filter ant noticed that one of the hoses from carb doesn't go anywhere, did try to look for other end but couldn't find it. Spend hours on the internet searching for some info but nothing. so you are my last hope :D
here are some pics
http://i44.tinypic.com/2gy86io.jpg
http://i41.tinypic.com/5n0wle.jpg
the bit that is circled red is where the hose comes from carb and ends in 30cm and i can't figure it out where i should stick it to :?
the carb is cvk 30 to my knowledge
desperate for some help all answers are appreciated
Best regards
Mytrenis (Peace)
Mytrenis (Peace)
It's a drain, it goes nowhere special.
Ignore it so long as it's not pointed at a naked flame. If it IS pointed at a naked flame, run.
Yeah....it's the float bowl overflow.....you should only get petrol coming out of it if the float sticks..
And as Bogof says....make sure it can't flow onto something hot or sparky.... :mrgreen:
Thanks a lot guys now can start putting all firing back.
just a shame that i ordered 2m hose :D
thanks again and ride safe
2m is overkill, unless the exhaust really does get that hot.
Just make sure nobody parks on it at traffic lights... :shock:
:P :P
ordered 2m just to have some extra if something else will need to be replaced. was trying to this forward and the extra 1m was just 30p
