inbed79 Posted February 28, 2012 Posted February 28, 2012 hi all is 10w40 semi synthetic engine oil for cars the same as for bikes was going to do a oil change on my xv535 and have5lts of 10w40 semi synthetic engine oil that i bought for the carthanks Quote
Decor58 Posted February 28, 2012 Posted February 28, 2012 No you can buy 10w40 semi synthetic oil for bikes from most bike garages and places like halfords.I believe there are a few different additives in bike oils, I believe it's because it lubes the gearbox too. Quote
eastanglianbiker Posted February 28, 2012 Posted February 28, 2012 i dont know what the differences are but some car oils can make the clutch slip on the bike i would always buy oil for bikes not cars Quote
Stu Posted February 28, 2012 Posted February 28, 2012 There's a thread about this with some in depth reading and a link to some tests been done You can use car oil its the same stuff same additives in it Quote
satnavsatnav Posted February 28, 2012 Posted February 28, 2012 Read this http://www.nightrider.com/biketech/oiltest1.htm as stu said was disscussed here http://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=42837 hope it helps Quote
Stu Posted February 28, 2012 Posted February 28, 2012 That's the one I would have found it but I'm on my phone at work Quote
Decor58 Posted February 28, 2012 Posted February 28, 2012 Read this http://www.nightrider.com/biketech/oiltest1.htm as stu said was disscussed here http://www.themotorbikeforum.co.uk/viewtopic.php?f=5&t=42837 hope it helps I stand corrected Quote
Colin the Bear Posted February 29, 2012 Posted February 29, 2012 I had problems with clutch slip using a cheap but fancy car oil in the bike. No problems with bog standard car oil tho. Cars run a dry clutch and most bikes run a wet clutch. It's the oils like the old Magnatech with the clingy when cold additives that cause the clutch to slip till the oil gets hot. With the price of oil these days it's worth giving it a go. It won't do any damage and if you do get clutch slip you can sort it with another oil change. Quote
rushwind Posted February 29, 2012 Posted February 29, 2012 i read the thread on oil,,,,,,,,,,,basically says one can use the car oil in the bike,i'll still use the bike specific, hm, , cos there isnt a great deal of difference in price, especially from halfrauds Quote
Stu Posted February 29, 2012 Posted February 29, 2012 There is when you can get 4 litres of good stuff for 10 quid Quote
MrBlonde71 Posted February 29, 2012 Posted February 29, 2012 I bought cheap (car) oil from Wilkos and have done about 500 miles without any problems so far.!!!! Quote
Donnie Brasco Posted March 2, 2012 Posted March 2, 2012 Never put car oil in your bike,bikes have a wet clutch(most anyway) and bike oil is designed to lubricate your gearbox as well as your engine components,for the sake of tenner a L which buys you castrol synthetic it just doesn't worth risk having a ruined gearbox and slipping clutch. Quote
Stu Posted March 2, 2012 Posted March 2, 2012 Never put car oil in your bike,bikes have a wet clutch(most anyway) and bike oil is designed to lubricate your gearbox as well as your engine components,for the sake of tenner a L which buys you castrol synthetic it just doesn't worth risk having a ruined gearbox and slipping clutch. think you need to read the link above Quote
megawatt Posted March 12, 2012 Posted March 12, 2012 What do you expect to happen in 500 miles FFS!!! Oil is the biggest moving part in the engine, you change it once or twice a year. Buy the best that you can afford. If it specifies semi, use semi not fully synth. Use bike oil, get ripped off, but have peace of mind Quote
Colin the Bear Posted March 15, 2012 Posted March 15, 2012 Paying too much keeps me up at night. So no peace of mind there then. Never believe sales blurb and hype. Synthetic...semi synthetic...sounds very technical and scientific, but it all comes out of a hole in the ground.WW1 aero engines were lubed with castor oil. The most important thing about oil is that you have some in. Quote
