Honda VT500 help?
Hi All
This is my first post so all tips and info welcome.
I recently pick up an old Honda VT500E. A great cheep bike to play around on.
However it has an oil leak which is bugging me.
The leak is coming from the rubber boot between the engine and the drive shaft. Although
I suspect this is just where the leak is manifesting itself. Having looked through a number
of technical manuals this is a start and stop point is and I cannot find a decent explanation
or photo of what’s behind the boot.
I am trying to find out if this is a easy fix or a major strip down, (i.e I just live with the leak)
Any ideas? :?
sounds like the output shaft seal could be leaking or the middle gearbox has blown a seal you will need to move the boot far enough back to try and see whats going on,failing that its either rear wheel off diff unit off swinging arm off or engine out to check
Thanks eastanglianbiker
Now found the page titled output gear case with it showing an oil seal so this looks like
the culprit. The leak only becomes apparent when the bike is hot and I've been on a decent run.
It doesn’t leak when standing. So it looks like the swing arm and rear wheel off to replace.
A snow day job, me thinks :roll:
Has anybody else actually done one of these?
you have to remove the wheel and swinging arm before you can get to it
you need a special tool the remove the swinging arm
http://www.ebay.co.uk/itm/HONDA-VT500-V ... 3cc9189854
the output shaft carrier is held onto the gearbox with 4 or 5 bolts so you need a new gasket as welll as the seal
Cheers guys
yep will probably need a gasket as well.
there are 3 cap head bolts holding the shaft to the drive unit
Do you have any idea what the official name for the seal is..?
or where I can get one
oil seal on google gets you alsorts of hits... :?
