Guest Posted December 23, 2012 Posted December 23, 2012 Hi there im completley new hire. Got a question abaut decat pipe. Is it street legal for bikes? Cheers Quote
Tango Posted December 23, 2012 Posted December 23, 2012 Welcome to the Motorbike Forum mate.......maybe head over to the Newbies section to introduce yourself to the forum when you get a mo..... De-cat pipes are not illegal as far as I know.....but you need to check what effect fitting one would have on the mapping on your bike. Also if you remove the pre-cat but not the main cat you can have problems with the main cat clogging. All I know is for Triumphs 1050's if you remove the pre-cat you also need to disable the Lambda sensor as it can really b*gger up the fuelling on the bike......and you need to run a de-cat map for the ECU..... Quote
Lumor_uk Posted January 11, 2013 Posted January 11, 2013 Depending on year of bike it will be tested on emissions at mot time. Decat will cause emissions to rocket equals fail. Quote
megawatt Posted January 11, 2013 Posted January 11, 2013 Never had an emissions test on any of my bikes? Aftermarket pipes are not fitted with Cats, but not sure what the law is on removing one and keeping the original system without a Cat. The fuelling will be totally different without the Cat , so will need to rejet or fit a Dynojet Power Commander or similar device. A dyno set up is usually a good idea! Quote
Tango Posted January 11, 2013 Posted January 11, 2013 Never had an emissions test on my bikes either...... Quote
Lumor_uk Posted January 11, 2013 Posted January 11, 2013 Ah its only on import. Hack away and kill your grand children son Quote
sliderglider Posted January 11, 2013 Posted January 11, 2013 there are no emission laws in this country for bikes yet as far as i know Quote
