Tango Posted March 6, 2013 Posted March 6, 2013 Possible solution?....... http://www.ebay.co.uk/itm/IGNITION-SWIT ... 3f0d26057f Quote
Grumpy Old Git Posted March 7, 2013 Posted March 7, 2013 If you look at the wiring diagram, the two (unconnected at the mo) wires are in parrallel with the 'Kill' switch so, when 'shorted' the engine will stop.The only way you will be able to do that from the ignition would be to get a four-wire switch.Brakers will have a few available at a couple of quid but.... you may have to order a key!Personally, I'd re-fit the wires back to where they were (or just tape them up and tuck them (safely) away. Then it's ignition to start and ignition off & kill switch to stop (just like your video). Quote
